Message 1 of 5
Using my iPhone 6s abroad
Despite everything being switched on and having reset my network as prescribed by BT I'm having trouble using mobile data abroad. Also, my phone doesn't hop onto 4G. Can anyone suggest something that night work?
Thanks!
4 REPLIES 4
Message 2 of 5
Re: Using my iPhone 6s abroad
Have you enabled mobile Roaming in MyBT?
Message 3 of 5
Thanks for checking this. Yes, everything i switched on where it should be.
Message 4 of 5
Also check that there isn't an extra spend limit on the account..
Message 5 of 5
Thanks for suggesting this.  There isn't but it doesn't go on 4G at all so no using data unless I'm on wifi.
