Message 1 of 4
Using my own dual band router & cant get internet access
TP-Link Archer C50-AC1200 Dual band router. I am currently trying to use this router with my ADSL Connection as i have done with my previous 2 ISP'S, all of my settings are setup 100% correct on my router, ppp0e etc, i have all green lights & ready to go but when i connect to my router, it connects bo problem but i cannot get internet access. Is there a setting with BT i may have missed unlike my other 2 ISP'S or cant i use my router for some reason, although i should be able to. It does say on my pc & phone screen reset browser settings etc & this should solve the problem but it doesnt. Does anyone at all have a soloution to this or should i contact BT? Any help would be greatly appreciated.
G Crosby002016
3 REPLIES 3
Message 2 of 4
Re: Using my own dual band router & cant get internet access
@T3chn0W1z4rd_84
Surely this is just a router and will need a modem to connect to your ADSL service.
Just how did it work with your previous ISPs?
Message 3 of 4
You need to attach to router as here
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 4 of 4
IF ADSL then should be set to PPPoA not PPPoE which is vdsl
did you set router username to  [email protected] and password can be anything your router will accept
