Message 1 of 3
VC019 Error - Samsung TV App Guide Out of Sync?
I keep getting a VC019 error when trying to stream live video on the BT Sport app through my Samsung TV.
For some reason the guide is showing programs that were on an hour or two earlier, instead of the current time. After an hour or so the correct program shows up and I am able to stream live just fine again. Very annoying as I basically can't watch live sport until it's been on for at least an hour.
I've checked the time & time zone are correct in my TV settings, as well as changing manually. There doesn't seem to be a way to update time settings on the app itself but it must be related!?
I am able to stream just fine through the BT Sport app on my Xbox which is on the same WiFi. So frustrating! Anyone know of a fix for this?
2 REPLIES 2
Message 2 of 3
Re: VC019 Error - Samsung TV App Guide Out of Sync?
That's a new one - we've not had any reports of this.
You say you've checked the time and time zone - are they correct at the time you visit them? Or have you needed to manually change?
If the clock is correct, have you tried using the Return or Exit keys to quit the BT Sport app and then launch it again - does it still show incorrectly?
Message 3 of 3
Yes the time is displaying correctly when set to auto. Tried setting it a few hours ahead manually and had no effect.
Closing and re-opening the app doesn’t change anything, until the guide catches up to be within the start time of the live show it seems. Right now (10pm) the main channels page is showing shows between 4pm-5pm, yet the on demand content is up to date from live football this evening.
