Message 11 of 12
Re: VDSL - Dropout Once a day
@Keith_Beddoe  - Light stays constant blue as normal the entire time there is an issue.
Message 12 of 12
Then its just a wireless issue, and nothing wrong with your broadband connection.
You could try changing the wireless channel on the home hub, when you lose connection, but you would need a Ethernet connection to the home hub to do that. The home hub only has a choice of three out of 13 possible wireless channels.
