Message 1 of 10
What is this setup?
I finally found the point which the router is connected to. The purple cable is CCS CAT6 and I'm assuming the white box is a 'slave'? Extension? Could poor wiring here be a cause for poor upload speeds but perfectly fine download speeds?
9 REPLIES 9
Message 2 of 10
Re: What is this setup?
Message 3 of 10
Uncertain if that is a slave without seeing inside the socket. Where does the cabke go back to?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 10
I honestly have no idea, the purple cable goes up behind a wall, though I assume it's going to the master?
I had taken the front panel off (2 screws) to try and test the test socket though that actually worsened my results to 60 down 0.1 up.
I will take a picture of the inside and post when I can.
Many thanks for your help, also I hope you put jam first like the proper way 😉
Message 5 of 10
 what do we make of this, my untrained eye says that it is a slave / extension. Also the wiring job seems a bit 🤔
Message 6 of 10
That's an extention, nothing wrong with the wiring job.
Message 7 of 10
Okay that's great to hear, any ideas as to why my uploads are so slow in comparison?
Message 8 of 10
That is your master socket, as you say it has a test socket. hopefully there is not another socket prior to this one. That cable could go back to a utility cupboard somewhere.
Message 9 of 10
So is it an extension or the master socket (sorry!) It does have a test socket however the two times I used the test socket I got speed test results of 65down 0.1up (upload was abysmal on test).
many thanks for the help
Message 10 of 10
That type of socket is a linebox, it is a master socket however unless you can find the other end of the purple there could be another linebox/master prior to this one.
