Message 11 of 20
Re: What options are there when Fibre Broadband isn't fast enough?
@rjlucker wrote:
Our master socket is like illustration 6, although the phone line passes through a small (filter?) box on the way into the master socket.
Richard
What does the filter box look like, as there should be nothing before the master socket? I wonder if its something that should have been removed, like an old DACS or WB unit?
I assume the home hub is plugged directly into the broadband socket at the front of the master socket?
Any extension wiring must come from the back of the bottom part of the master socket.
Message 12 of 20
Is the filter box not just a junction box which connected the incoming openreach wiring to your internal wiring - normal 1 wire in and another 1 out to master
is the extension socket connected to the the master socket
Message 13 of 20
Thanks Keith,
The internal wiring consists of a single wire from the phone socket on the master socket to an extension socket on the other side of the same room.  Unplugging this from the socket does not affect performance or line noise.
I believe that the issue is with the line to the house which is both a long distance from the cabinet and in an area that has historically been prone to picking up radio interference from local transmitters. When engineers have been out (including when they replaced the cable from the post to the master socket) they've never achieved a sync speed of more than 24 Mbit/s when they've tested the line.
Cheers
Richard
Message 14 of 20
Here's the master socket.
I was incorrect in my previous post - the phone line doesn't pass through the filter box; the filter box is mounted immediately above the master socket.  This is all recent; a new line and new master socket were put in a couple of years ago.
Cheers
Richard
Message 15 of 20
Cheers
Richard
That just looks like a connection box. A filter would upset your broadband.
Unscrew the front and see what is inside, I expect you will find just a connection strip.
Does your phone line come in from a pole?
Its possible that you are not going to be able to get a faster speed, but its always worth checking at the test socket, but you have to take the master socket apart, and you would need a microfilter as well.
Message 16 of 20
Thanks for all of your input,
I've attached a photo of the contents of the connection box below in response to the previous request.
As mentioned previously, the speed that engineers have been able to achieve in the past via the test socket have been consistent with the actual speeds I get, so I'm confident that any speed limits are due to the quality of the line into the house rather than equipment or wiring within the property.
Given the lack of viable options available from BT (or any other fixed line provider) I've signed up to 3 unlimited mobile broadband on a rolling monthly contract so that I can split connections within the house between the two (and can cancel if it doesn't work out).  So far it appears to be working well and actually returns better speedtest results (except for the ping time) than my BT line for less money.
It's still frustrating to be paying for two separate broadband connections, but this seems to be the best compromise for me at the moment.
Richard
Message 17 of 20
Richard
That filter should not be in circuit, as it will affect your broadband speed. Not sure why its there.
You should be able to bypass it by connecting the in and out together without using any of the existing terminals. Just join the two loose ends together, and see if it improves your speed.
Be aware that there will be 50 Volts DC across the wires, so make sure your hands are not wet, as it will tingle.
Message 18 of 20
where does the 2 cables at bottom left of master come from/go?
Message 19 of 20
We need to see all the connections in the master socket to understand what is going on.
Message 20 of 20
That reminds me of the filters we used to fit to prevent radio interference on phone calls, from nearby broadcast transmitters. This was before the days of broadband, and it looks like its never been removed. It may have been assumed that it was just a junction box.
Its not going to help VDSL.
