Message 11 of 13
Re: When my phone rings and I answer I just get static
Hi, just to let you know I have had a few of these phones and when I have had just static it has been solved by getting new handset batteries. Maybe this was what was needed. Jo
Message 12 of 13
Thanks for your reply I had changed batteries and even bought new phone. BT just been out and it seems the problem was that someone had disconnected the underground connection
Message 13 of 13
Problem solved, BT has just been and it seems someone apparently had disconnected the underground connection! Thanks for your advice/help
