Message 1 of 4
Whole Home premium disc setup: Devices disconnecting.
Just asking if anyone has had similar issues or remedies for possibly me issue.
On 2 occasions in 4 days my devices are not able connect to my discs, I've had no issues like this since I can remember. Using a wired device and logging in, everything seems normal. here's a snippet from my log
 2021-11-30 11:27:43 | 6 | WIFI | 209 | <Device Hostname> (06:30:86:5B:72:DD) has deauthenticated (<Reason>)
2021-11-30 11:27:52 | 6 | WIFI | 209 | <Device Hostname> (22:DE:72:D1:FB:F3) has deauthenticated (<Reason>)
2021-11-30 11:28:07 | 6 | SYS | 724 | ISM bus remote communication started.
2021-11-30 11:32:55 | 7 | WEB | 503 | 192.168.1.9 successfully logged out of the web interface with guest account
THESE ENTRIES WERE PRESENT BEFORE RESTART
2021-11-29 08:05:26 | 6 | WIFI | 209 | <Device Hostname> (96:F4:D2:7B:61:C5) has deauthenticated (<Reason>)
2021-11-29 08:05:50 | 6 | WIFI | 207 | <Device Hostname> (96:F4:D2:7B:61:C5) has authenticated successfully
2021-11-29 08:05:50 | 6 | WIFI | 206 | <Device Hostname> (96:F4:D2:7B:61:C5) has connected to the 5G network with signal strength -48
2021-11-29 08:06:53 | 6 | WIFI | 209 | <Device Hostname> (96:F4:D2:7B:61:C5) has deauthenticated (<Reason>)
2021-11-29 08:06:59 | 6 | WIFI | 207 | <Device Hostname> (22:DE:72:D1:FB:F3) has authenticated successfully
2021-11-29 08:06:59 | 6 | WIFI | 206 | <Device Hostname> (22:DE:72:D1:FB:F3) has connected to the 5G network with signal strength -78
BT app was unable to connect until I restarted one of the affected devices. My iphone wifi settings report no internet connectivity and details of router  are missing?
thanks
3 REPLIES 3
Message 2 of 4
Re: Whole Home premium disc setup: Devices disconnecting.
Hi, @redeye I'm sorry to see you've had problems with your Whole Home premium discs. I've noticed you haven't had a response from other members of the community and if you still need support with this I'd recommend getting in touch with the helpdesk on the below contact details.
By phone: 0808 100 6116
Monday to Friday 9.00am to 5.30pm
Saturday 9.00am to 2.00pm
By email: [email protected]
Neil
Message 3 of 4
Thanks @NeilO , if it happens again I'll call the numbers you've linked.
Not had any devices drop since, fingers crossed.
Message 4 of 4
@redeye no problem, if you email them the logs they may be able to tell you what happened.
Neil
