Message 1 of 5
Whole home Wi-Fi not connecting
Recently had a whole home Wi-Fi system stopped working and managed to get it replaced.
set the new discs up no problem and they worked great, now when I get up in the morning the light is purple as if it’s updating even though automatic update is turned off, and sometimes it has started to work by the time I get home other times it’s still doing nothing.
I can reset the main disc and set it up again but the next morning it’s back to a flashing purple light and it does nothing.
4 REPLIES 4
Message 2 of 5
Re: Whole home Wi-Fi not connecting
Hi @nickjohn
Are you able to confirm which firmware version your Whole Home Wi-Fi is running (you can check via the app or web interface)?
Dan-O
Message 3 of 5
Firmware v1.02.12 build 2
Message 4 of 5
Hi @nickjohn
It sounds like there may be a problem with your discs - I'd recommend contacting the helpdesk via [email protected] to report the issue and arrange a replacement.
Dan-O
Message 5 of 5
Cheers I will do
