Message 1 of 5
WiFi disc
I have Fibre 250 with Halo 1 router with 1 Wi-Fi disc. If my printer is connected via the disc and my laptop/ phone is connected via the hub they will not communicate and I get an error to check that they are both on the same network. I have the same SSID throughout.
Can anyone please offer any advice.
Dave
4 REPLIES 4
Message 2 of 5
Re: WiFi disc
Rebooting the hub/router usually sorts out problems like this.
Message 3 of 5
Re: WiFi disc
Thanks Earthling. I have done that and it does work for a period of time before failing again.
Message 4 of 5
Re: WiFi disc
  • No Halo 1 experience but sounds like a firmware problem. My Smart Hub 2 used to do  similar 2-3 times a week until I turned smart setup off.  Stable now.
Message 5 of 5
Re: WiFi disc
Thanks again. I had similar problems until I switched off the 5g then all seemed ok. The problem does seem to have started again since I added the wi-fi disc.
