Message 11 of 30
Re: Wifi connection to computer
I have a USB wifi dongle which is showing on i.e. lit, but no show in Network and Internet
Message 12 of 30
Unplug the dongle and try it in another port
Message 13 of 30
Tried that - no difference. If i unplug the ethernet cable, would that make a difference to the wifi option turning up?
Message 14 of 30
You should be able to see a list of the available Wi-Fi networks even with the ethernet cable plugged in.
Have you disabled the wireless adapter?
What operating system are you running?
Message 15 of 30
I haven't disabled the wireless adapter (as far as i know) - never touch anything if I can help it. No wifi networks appear. Windows 10
Message 16 of 30
When you left-click the network icon in the system tray (bottom Right Hand corner of your screen), do you see the blue button and a list of Wi-Fi networks as below.
Message 17 of 30
Only Network 2 appears
Message 18 of 30
I have no idea what you mean by that.
Do you see the blue button?
Message 19 of 30
Sorry - all that happens when I left-click the network icon is get Network 2 - no blue button, in fact, no buttons at all. Just the words Network 2 on a grey background. Thanks for all your help so far.
Message 20 of 30
The screenshot I posted is, as far as I know, standard to all windows 10 machines so if you're not seeing that then I don't know what else to suggest.
Have you ever been able to use Wi-Fi on that machine?
