Message 11 of 22
Re: Windows email password problem
Sorry Shaky1981 but i am not sure what you mean by 'other option' ??
Anonymous
Not applicable
Message 12 of 22
you are using te mail clent in windows 10 the one that has mail client built in ? re ad it if you are mines been sync without problems
this should then pop up
Message 13 of 22
@Anonymous you are just muddying the waters, the OP doesn't have a problem with the account, just the app not remembering the password.
Anonymous
Not applicable
Message 14 of 22
i had the sam problem readded the acount and it now syncs pefectly it a bug n the programme
how do peoplw think i got this notification im repling to
dont worry i wont reply again
@licquorice
Message 15 of 22
I know you are only trying to help, but yours was a different problem.
Message 16 of 22
Do you think its worth while deleting &  restarting the BT account, I really don't want to lose some of the emails though ??
Message 17 of 22
I tried creating a new BT  email account yesterday & today the same thing - had to enter the password again on Windows Mail..
Message 18 of 22
I have also added an old Gmail account to Windows mail so I will report if that's working OK tomorrow..
Message 19 of 22
I did put  Gmail & Yahoo mail accounts thru Windows mail & they both work OK..
Anonymous
Not applicable
Message 20 of 22
well i dobt know what to tell you mine works find i added it uner the other opten put my wnail and passwoed in no problems at all
if you made your own bt email adress try making it a favourite in the email settings
or do check for updates on the microsoft store in windows ten
