Message 1 of 10
Won’t connect but blue lights in
So my bt hub has blue lights on and it won’t connect to anything!! I have done all the resets but still nothing can anyone help
9 REPLIES 9
Message 2 of 10
Re: Won’t connect but blue lights in
Hi @Grainne1986,
Thank you for posting. I'm sorry if you're having problems with your connection.
What devices are you using to connect to your hub and does the issue occur on all of those devices? What error message to you get?
Can you check if you can access your hub manager?
  1. Open a new web browser
  2. Type 192.168.1.254 into the address bar
And if so what does is show under Broadband connection status?
Thanks,
Paddy
Message 3 of 10
It says that the connection stays is connected but it still won’t connect to anything in the house weather it is a phone tv or camera @PaddyB
Message 4 of 10
Message 5 of 10
How do I turn off smart set up @licquorice
Message 6 of 10
have you turned of smart setup
Turn Off smart setup
Message 7 of 10
By following the instructions in the link I posted!
Message 8 of 10
I tried that link and followed the instructions but no option on smart set up on my page! @licquorice
Message 9 of 10
I logged into that link they gave and I don’t have the option of smart set up
Message 10 of 10
