Message 11 of 13
Re: Where is the Xbox series X code?!
Ok, thanks for the reply.
The previous moderator said "Everyone on the mailing list has been emailed - if the email isn't in your junk / trash folder, then it's been missed or the registration didn't go through at the time"
Is that not correct?
Message 12 of 13
Hi @benalfa147,
Thank you for replying. There can be 1000s of users on the waiting list and the BT shop might only get in a few 100 consoles when the stock arrives.
Each console gets a unique code and that's emailed out to users on the list. Often the demand is great than the available stock.
Each code entitles that user to to order a Console. If they don't place an order in a few hours the code expires and a new one is generated and emailed to the next user on the list.
Thanks,
Paddy
Message 13 of 13
Thanks for the information on how it works, that's great
