Message 1 of 8
blocked senders and domains
how do I review these on BT online as I think some addresses have been added in error?
7 REPLIES 7
Message 2 of 8
Re: blocked senders and domains
Settings > Mail > Blocked senders
Message 3 of 8
Log onto your email account then click on settings found by clicking on your username. Go to Mail then Block senders List and scroll through until you find the ones you want.
Message 4 of 8
Hi @Cagey1  and welcome to our community.
Both @gg30340 and @licquorice advice is sound. Can you try that and let us know if it answers your question?
Cheers
David
Message 5 of 8
Thanks DavidM, @gg30340 and @licquorice, it is actually  the blocked senders and domains that may have been blocked on the  BT web site that I am looking for.   I am not sure whether BT have blocked emails from people or whether they have added my entire address list to the blocked listing by mistake.
Thanks for you help
Cagey
Message 6 of 8
The advice you were given was in relation to the BTMail system. I am not sure what you mean about  " blocked senders and domains that may have been blocked on the  BT web site"
 If you explain exactly what you mean perhaps somebody may be able to assist.
Message 7 of 8
@Cagey1 I suspect what you are referring to is the BT spam filters. In which case there is no list you can access, all you can do is add the senders to your safe senders list.
Message 8 of 8
thanks licquorice - I'll have to get on to BT
