Message 1 of 2
bt mini hub password
i can’t find the password to my mini hub please bro it’s not on the sticker
1 REPLY 1
Message 2 of 2
Re: bt mini hub password
Hi @aiden, welcome to the community and thanks for posting. The password card is in the box, if you can't find it remove the back cover and the password will be on the sticker behind the cover.
  1. Plug in and switch on your Mini Hub and wait for it to connect to the 4G network
  2. Follow the instructions in the BT welcome booklet and take a look at these FAQs if you have any issues
  3. Find the best signal location in your home - this is often near a window - and plug in the Mini Hub to charge. The battery life is around six hours, but you may want to keep it plugged in to make sure your home stays connected. The charging cable provided can be used with a USB plug, which means you can move your Mini Hub around to find the best coverage. You need 4G for the best performance, but it works with 3G too
  4. Connect your wi-fi devices using the network name and password shown on the password card. This is included in your box. If you can't find it, just remove the back cover and you'll find a sticker showing the network name and password
Neil
