Anonymous
Not applicable
Message 1 of 11
does this mean ny conection has dropped
 See network uptime
have not  notice anything wrong with my connection just went to make a schedule for the hub lights and noticed it
10 REPLIES 10
Message 2 of 11
Re: does this mean ny conection has dropped
yes  your hub dropped your internet connection 2+ days ago  it could have been during the night and maybe even for a hub firmware update   check hub stats in advanced settings technical log information and see if firmware update
Anonymous
Not applicable
Message 3 of 11
02:37:09,30Jul.connectionWAN2_INTERNET_PTMdisconnected.[ERROR_NO_CARRIER]
could it be dlim as ive just joined ?
Message 4 of 11
It may have been the DLM making adjustments  but as long as connection is within expected range then just watch in case it keeps dropping connection
Anonymous
Not applicable
Message 5 of 11
dropped again this time it looks to me as if the router rebooted aswellCapture.JPG
Message 6 of 11
That is normal after a firmware update.
Anonymous
Not applicable
Message 7 of 11
bt firmware updated on th 22nd of jjuly
well i suopposed its a good sign that router remotly rebooted my line is stable guess i should be lucky it not doing it 5 6 times aday
Message 8 of 11
as system and network uptime very similar that suggests that you hub has lost power - power cut? - if just a drop in connection then that only affects network time
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Anonymous
Not applicable
Message 9 of 11
Serial number:
Firmware version:v0.27.06.04290-BT
Firmware updated:Thu Jul 22 10:28:08 2021
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:0 days,08 Hours59 Mins21 Secs
Data rate:20 Mbps / 80 Mbps
Maximum data rate:29.580 Mbps / 84.063 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:11.9 / 6.5
Line attenuation:6.7 / 12.1
Signal attenuation:6.6 / 14.0
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:99.7 MB Uploaded  / 2.1 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
Message 10 of 11
stats look ok and max for fibre 2 80/20mb  it is also top of expected speed range
the few drops have not affected your connection speed
any line noise?
