Message 11 of 25
Re: Whats the first speed that would need engineer visit
can you post results
was it FTTPoD? as that is not same as FTTP
Message 12 of 25
Message 13 of 25
certainly shows FTTP not G.Fast
you need something like this installed
Message 14 of 25
so whats the fastest on fttc is it 100 which im getting then 300 and up i need this?
Message 15 of 25
normal FTTC is 80mb  you have FTTP available to you and to upgrade you would need to contact 08005874787
there is not G.Fast available according to dslchecker
Message 16 of 25
I merged both your posts as covering same question/subject
Message 17 of 25
So the "free" upgrade offered by BT to "Full Fibre 100" from what your saying and the mail we got says max speed 63 is actually just fttc and not full fibre. So isnt that misrepresentation?
If its full fibre we would need the ONT adapter box which they have not said they will be sending, so its just the highest FTTC and not FTTP per the advert. Or am i missing something or do i need to speak to someone on phone as i cant find an direct webchat for BT an more.
Message 18 of 25
phone the FTTP team I have already posted the number and see what they offer
Message 19 of 25
just to finish off the thread incase anyone else finds it. I have just spoken to FTTP team over the order placed.
We received the advertising leaflet for "free upgrade to full fibre 100" and accepted it online. However, it appears that the BT ordering system didnt upgrade us to Full Fibre it just "upgraded us" to the fastest FTTC. The help desk told me to let the upgrade go through but on the first day ring up the upgrade team and they would arrange for propper FTTP to be done. So to me this is an error and possibly misrepresenting the package on BT site.
I will do as they said and ring on the 1st but i shouln't have to! this is a bit bad really as the site did an upgrade that isnt really an upgrade!
Message 20 of 25
I also have a letter from BT giving £0 pm upgrade to fibre 100 with BT halo1.
However, when I tried to upgrade online, the checkout showed £52.49pm!
It says on the letter an engineer needs to visit. I believe they need to send something in the post first (unfortunately not a new router).
I am hoping this package will stop me losing my broadband connection all the time. I have tried all the troubleshooting...
It looks like I need to ring BT even though the advice is not to!
