Message 1 of 46
Noise margin change and speed loss
Hi,
Ive recently noticed ive lost speed and my noise margin no longer seems to aim for 3.5 it aims for 4.5 instead?
Heres a screenshot of my routers stats:
45 REPLIES 45
Message 2 of 46
Re: Noise margin change and speed loss
what caused the reset just over a day ago? probably when noise margin increased and speed reduced slightly
from your stats you have G.INP active hence why your speed is actually higher than attainable
have you any noise on line  dial 17070 option 2  should be silent and best with corded phone
Message 3 of 46
Thanks for the reply, I'm not sure why the router rebooted itself the other day, I find that happens every couple of weeks anyways. What im confused about is my noise margin used to be like 3.4 and I used to be connected at like 71000. Just wondering why the sudden change. Theres no noise on the silent line test either.
Does it look to you like it's trying to aim for a 4.5 noise margin?
Message 4 of 46
There are only 2 target noise margins. 6.0dB without G.INP and 3.0dB with G.INP.
Message 5 of 46
If no noise on quiet line test then as long as you can now maintain a stable connection then your speed should return automatically
Message 6 of 46
So best thing to do is just leave it a couple weeks and the speed should go back to normal when the DLM see's that I can hold a stable connection? Could the router be faulty in anyway?
Message 7 of 46
I drop in connection doesn't make hub faulty. Just watch and hope that it is now stable
Message 8 of 46
Your stats show a firmware upgrade on the 20th June. Would that not account for the reboot?
I've noticed (Hub 6) that firmware updates can also suddenly alter the figures for certain items, in my case line attenuation and signal. Nothing changed on the line, only the Hub firmware and so presumably  the way the figures are interpreted  and displayed.
For the Hub 6 I usually see a 6.3/6.3 or thereabouts noise margin, however the Hub 6 does weekly reboots following the latest firmware (well mine does) and I caught it the other day displaying an altering noise margin. I think it was 4.1/6.3 and then it went to 4.7/6.3 following which it rebooted (on cue, the 7 days was up) and the margin reset back to around 6.3/6.3
There seems a lot of ambiguity over all this and some of the Hub stats are just plain wrong such as data amounts. I think I would know if I uploaded 15Gb after a reboot but something of that order was showing.
Message 9 of 46
Hi,
I posted the original problem I was having on this thread a few months ago and thought the problem with my speed would sort itself out however it has now taken a turn for the worst as you will see below with my stats:
It now seems to have locked itself aiming for a 7.5 noise margin. No matter how many times I reboot the router it wont go above 54.999.
It use to aim for a 3.5 noise margin is there something wrong with my line?
Message 10 of 46
this thread you started about 18 months ago!
if you are rebooting the hub to try and improve your speed and lower noise margin then you are actually achieving the very opposite  to get any improvement you need a stable connection but looking at your stats your attainable in only 59mb now compared to 67mb 18 months ago
check for line noise  dial 17070 option 2  should be silent and best with corded phone
