Message 1 of 3
parental controls stuck on
My BT parental controls are stuck on despite social media being checked ‘off ‘ in all areas and ‘ light ‘ wifi restrictions -HELP!
2 REPLIES 2
Message 2 of 3
Re: parental controls stuck on
I had the same problem a while ago, a moderator was able to arrange a resolution to this issue. There is nothing you can do yourself to resolve this.
I don't know how you 'summon' a moderator though - hopefully a helpful mod is watching
Message 3 of 3
Hi @EmSim
Welcome to the BT Community and thanks for posting!
I'm sorry for the problems you're having with Parental Controls.  The Community isn't going to be able to help with this.  We'll need to pick this up and give you a hand from here.
I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks for the shout out @oakserver  😁
Cheers,
Robbie
