Message 1 of 3
phone socket
Hi The way engineer setup my phone and broadband is as follows. The line enters the house then  through a single socket box then onto the master socket. The phone no longer works on the single socket this has always been a troublesome socket for plugging the cable in. The phone does work on the master socket.  Would I be charged to replace the single socket or is it easy to replace it myself? Cheers
2 REPLIES 2
Message 2 of 3
Re: phone socket
I suspect the engineer has crimped the incoming wires to the single socket to the external wires from the single socket. Technically making a through joint.
You could not just connect a socket at this point as any extension sockets need to feed from the front plate of the main socket.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 3
Re: phone socket
Hi I never made it clear that this single socket (master socket at the end of the route) worked with a phone for a few years but was always  difficult to put the plug back in. When I pushed the plug in the other day I heard a crackle. I removed the faceplate and a wire became lose. You are right some wires have been crimped I suspect I need to replace the faceplate and  sort what I think is a couple of wires to their correct position. cheers
