Message 1 of 17
serial number on ont
Had fttp installed on 5 Aug, however still not activated as apparently a serial number needs to be given to OR. Trouble is there does not seem to be any number on my ONT thing. Any ideas as to where I will find this number?
Thanks.
16 REPLIES 16
Message 2 of 17
Re: serial number on ont
@Starwire  should be able to help you out there when he drops in. I don't know where it is on the newer ONT's
Message 3 of 17
@jenny28460
The engineer who did the install should have activated the serial number at the time of the install.
Why he didn't who knows, why did he leave before testing it was working.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 4 of 17
Did the engineer leave the box that the ONT came in. Had my fitted yesterday and he left the box which has all the details on a sticker on the side.
Message 5 of 17
Thanks for responses.
Apparently there was a fault somewhere in the local area that needed to be fixed first. Now we are stuck with waiting until Sept for another engineer visit. Don't know why they can't call the original installer to ask him. This is such a pain. No-one seems to know what they are doing. Have hunted all over the ONT for any sign of a number or barcode but there is none.
Message 6 of 17
Only had the box that the hub came in.
Message 7 of 17
Is it a Nokia ONT or a Huawei one?
The Nokia ones are about 4inch Squared whereas they Huawei are about 8 inches by 5.
The Huawei ones usually always have a sticker with the Serial Number on the front, it’ll begin with SN then a long series of numbers, usually the first batch of numbers end 443.
The Nokia ones only have the Serial Number on the back and usually begin with AL, it’s the sticker in the middle at the top.
Message 8 of 17
It's a small square thing so Nokia I would guess. No way of getting the number then..short of taking it off the wall.
Message 9 of 17
Yeah, you’ll have to take it off the wall by pulling it up as it’ll be held on by two screws.
Message 10 of 17
So slide it upwards and it should come off?  Is there a front cover that comes off?
