Message 1 of 3
Fttp and hub 2
Just moved into a new build with fttp
openreach  have installed a modem in a cupboard in the entrance hall ,router is generating a lot of heat in this tiny cupboard   And as the hub 2 is now in this cupboard , and I’ve no way to connect devices to Ethernet ports
I have 3 sockets in front room And one in each of the other rooms  that look like in the photos , Any idea what they are ,
they look like a cross between Ethernet and a phone plug...
2 REPLIES 2
Message 2 of 3
Re: Fttp and hub 2
Is there not a panel in the cupboard of similar connections maybe 4 or more so you connect Ethernet from hub to panel and you conenct Ethernet to the other end of the socket in one of your rooms and then to your device
Message 3 of 3
Re: Fttp and hub 2
Someting like this @imjolly ?
2018-09-25 17_13_30-Fibre network guide - fibre_developer_handbook.pdf.png2018-09-08 17_32_26-Copper network handbook - copper_developer_handbook.pdf.png
