Message 1 of 15
slow connection
I'm having problems connecting to all sites and web pages on all devices. The only way I've got on here without it timing out is connecting to Fon. Done a speed test (took ages to load) and it says I'm connected at between 19 and 23mbps so I'm stumped?? anyone got any ideas???
14 REPLIES 14
Message 2 of 15
Re: slow connection
@Tyke107
Good Morning,
What device/s are you using to load the pages, and how are you connecting WiFi or Wired?
If it's WiFi it maybe the channel that needs changing.  This can be done on any BT Hub just depends which one you have.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 3 of 15
Re: slow connection
phones, laptops and TV box all running like this and the TV box is through ethernet cable. Not which router I have but it's a couple of years old. I'm just confused as to why it's happening seeing as a speed test says it's running at it's normal speed???
Message 4 of 15
Re: slow connection
@Tyke107
what router is it?
If you post the model one of the other members can adv how to check the speed at the router.
Kind Regards
CJT80
Message 5 of 15
Re: slow connection
it's a BT smart hub but it's just the wifi that's not working properly on all devices.
Message 6 of 15
Re: slow connection
if hh6 then probably start with factory reset - press recessed button on back and hold 20/30 secs until lights flash
when hub restarts then turn off smart setup
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
then I would split the 2.4/5ghz networks and also select channels manually
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/i-want-to-improve-my-wi-fi/how-d...
Message 7 of 15
Re: slow connection
just tried that but no joy. Ethernet seems to be working fine but having to log into BT FON to be able to reply on here through wifi
Message 8 of 15
Re: slow connection
post hub stats  go to advanced settings then technical log information
Message 9 of 15
Re: slow connection
Product name:Smart Hub
Serial number:+088044+1813010687
Firmware version: v0.09.06.05093-BT
Firmware updated:Mon Jul 16 07:52:15 2018
Board version:01
DSL uptime:0 days,07 Hours12 Mins07 Secs
Data rate:5.889 Mbps / 27.355 Mbps
Maximum data rate:5.867 Mbps / 27.368 Mbps
Noise margin:6.0 / 6.0
Line attenuation:36.3 / 26.8
Signal attenuation:25.7 / 23.4
Data sent / received:161.4 MB / 3.6 GB
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:Tykes
2.4 GHz wireless channel:Automatic (Smart Wireless)
5 GHz wireless network name:Tykes-5
5 GHz wireless channel:Automatic (Smart Wireless)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:94:6A:B0:AC:18:20
Software variant:-
Boot loader:0.1.6-BT (Fri Sep 9 10:05:09 2016)
Message 10 of 15
Re: slow connection
because i'm not too bright when it comes to all this....i finally got a speed check done and my download is 23+mbps but my upload is between 0.05 and 0.01mbps. So looks like that could be the problem???
