Message 11 of 15
Re: slow connection
your connection time is only 7hrs was that manual reset or hub dropping connection?
apart from that stats look ok
were you using wifi to try speed test?  did you run btspeedtster https://www.speedtest.btwholesale.com/  must be with ethernet connection
Message 12 of 15
Re: slow connection
it was an ethernet test, which is the same as the wifi test. Looks like i'm gonna have to ring them
Message 13 of 15
Re: slow connection
Hi @Tyke107 I'm sorry to see you're having issues with your broadband. From the router stats you've posted the upload speed you're getting is 5.8Mbps are you sure this is not a wireless issue? Is it possible for you to post the speed test results so we can take a look at those.
Message 14 of 15
Re: slow connection
spoke to someone at BT and there is some kind of fault so i've gotta put up with it for 3 more days as they monitor it. Then i might something done about it. Think it is a wifi issue due to the more or less non upload speed
Message 15 of 15
Re: slow connection
Hi @Tyke107, can you try refreshing the wireless channel by following the guidance on this link?
