Message 1 of 7
Slow Connection
Hey, I my mbps drop down from averaging from 60mbps to 9mbps  and i’m paying £39.99. The speed on my contract says at least 60mbps is there any way I can get back my normal speed to 50-60mbps I’ve been running 9mbps for a month now. Please Reply Thanks!
6 REPLIES 6
Message 2 of 7
Re: Slow Connection
Hi akocs4m
Thanks for posting can you confirm if you are connecting wirelessly or wired with an ethernet connection?
Stuart
Message 3 of 7
Re: Slow Connection
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
run btspeedtester and post results  must be done with ethernet connection  https://www.speedtest.btwholesale.com/
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 4 of 7
Re: Slow Connection
I'm connected through wired enthernet connection and  I did check it with https://www.speedtest.btwholesale.com/ and its running at 9.46 mpbs
Message 5 of 7
Re: Slow Connection
posting the information requested will help the forum members help you.  not a lot of help without information/stats
Message 6 of 7
Re: Slow Connection
Hi, This is the status of my router and yes I did test it on https://www.speedtest.btwholesale.com/ still running at 9.46 mpbs
Message 7 of 7
Re: Slow Connection
No-one asked for the hub status page. Please post info @imjolly  requested.
