Message 1 of 6
smart bulbs
Hi, as anyone successfully connected smart bulbs or smart plugs with BT Home Hub 2.
i have tried splitting the 5 and 2.4 .
turning off Smart setup. even turned off the wifi protection, all of my equipment work on on my old router Home Hub 5, any help appreciated
5 REPLIES 5
Message 2 of 6
Re: smart bulbs
If you have the SH2 you cannot split the 2.4/5ghz networks
as the bulbs probably used 2.4ghz network did you try turning off the 5ghz network and see if you can then connect. If it works then you can switch 5ghz back on
have you tried changing the wireless mode from 1 or either 2 or 3
Message 3 of 6
Re: smart bulbs
Hi
yes i have tried turning off the 5ghz network . it didn't help. i turned off Smart setup also. i have not seen modes 1.2.or 3 i have not seen that on the hub interface, i did see a suggestion online to remame the SSID but felt that was a step to far for me . where do i fine the mode setting you refer to
thanks
Paul
Message 4 of 6
Re: smart bulbs
Renaming the SSID is only of any use if you can split the networks which you can't
try going to hub manager then advanced setting then wireless
Message 5 of 6
Re: smart bulbs
eureka !
Let there be LIght
Hi , your suggestion to change the mode from 1 to 2 or 3 as sorted the issue out completely.
Bulbs, Plugs connect to my app  ( avatar ) within a couple of seconds. and Alexa also works fine.
many thanks for the help i was nearly ready to bin all of my equipment and give up .
one final question if i may ?
should i return the mode back to 1. will i lose broadband performance if i leave it on 3
thanks in advance
P Stubley
Message 6 of 6
Re: smart bulbs
It shouldn't make much if any differences to your wireless devices but not connected You could try moving back to mode 1 but it maybe cause devices to drop connection
