Message 1 of 7
xbox one s
hello, we have a new xbox one s that we can't install.  It finds the wifi and connects but then says Looking for updates and then fails to go any further.  We had another one that did the same but wee thought that was the console as second hand but this is a new one doing exactly the same.  So it must be a broadband issue so any ideas please.
thanks
6 REPLIES 6
Message 2 of 7
Re: xbox one s
@helenw1
Welcome to this user forum.
Which BT Home Hub do you have?
Message 3 of 7
Re: xbox one s
I think we have home hub 2 - it is fairly new,  got when we moved over to halo
Message 4 of 7
Re: xbox one s
Turn off smart setup and try again.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Message 5 of 7
Re: xbox one s
Thanks for that but smart set up.is on and I can find the xbox listed.
Message 6 of 7
Re: xbox one s
Turn it off, as it can cause lots of problems.
Message 7 of 7
Re: xbox one s
thanks for that but still not working.  Have turned smart setup off
