Message 1 of 8
wifi & Admin password issues on brand new hub 2.
Evening all, So today I received a brand new smarthub 2, upon installing, neither the wifi password or admin password are working.
I have tried the usual of factory reset with a pin, connected via ethernet, this lets me in however as admin password doesn't work then it wont allow me to change the SSID or Password, I have also tried to do a admin password over ride. again as the admin password isn't liked then that doesn't work either.
i have managed to connect 1 device via WPS and also spoke to BT who changed the password so i can log wifi devices on however i still cant change admin password or SSID.
any ideas??? thanks.
(also its nothing silly like 0 and o)
7 REPLIES 7
Message 2 of 8
Re: wifi & Admin password issues on brand new hub 2.
If a factory reset hasn't solved the problem, the only thing to do is to get a replacement hub from customer services. Be insistent that it is faulty.
Message 3 of 8
already sending a replacement just wanted to try and sort this one.
thanks.
Message 4 of 8
Please let us know if the new one sorts the issue @Houghton19 .
Cheers
David
Message 5 of 8
Sorry, forgot to update, yes a new one solved it. Thanks.
Message 6 of 8
There's the possibility that you've been sent a reconditioned one that hadn't been reset back to factory spec and the previous person had changed the passwords...
Message 7 of 8
Which a factory reset would have cleared had the hub not been faulty.
Message 8 of 8
Hi @Houghton19,
Thank you for posting back to update the thread.
Thanks,
Paddy
