Message 1 of 3
2.4GHZ and 5GHZ Bands BT Smart Hub 2
I have recently swap to BT broadband.  and i lost all of devices connection ie; smart lights / smart pet feeding machine / Smart devices. it suppose to connect via 2.4GHZ but i couldn't choose wifi 2.4GHZ on my mobile so i couldn't connect to all smart devices. could anyone help me with this please. i saw some posted regarding update firmware version. how could I update that? my firmware version is v0.30.01.08093-BT.
I also try to switch off 5GHZ but mobile still not recognise it.
2 REPLIES 2
Message 2 of 3
Re: 2.4GHZ and 5GHZ Bands BT Smart Hub 2
you cannot split the networks on SH2
have you turned of smart setup
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
you can turn off 5ghz network and then clear connections on phone and try connecting to hub ssid
you are on the most up to date firmware for hub
Message 3 of 3
Thanks! problem solved !!!
