Message 1 of 5
Advanced Phone Z Twin, caller is too quiet
Hello, need some help please. I have Advanced Phone Z Twin, one of the handsets is perfectly fine when someone calls and I can hear them very well. However the second handset the caller is so quiet and I have to turn this onto loud speaker so I can hear them. I have checked whilst on a call both the call and volume setting and both are at maximum.
Any ideas please what setting it is that will adjust the volume of the caller so I can hear them properly. Thank you
4 REPLIES 4
Message 2 of 5
Re: Advanced Phone Z Twin, caller is too quiet
@LE197029
It could be a faulty earpiece, which is why the speaker still works. Try the helpdesk.
Product helpdesk information
If your phone is within warranty:
By phone: 0800 145 6789
Monday to Friday 9.00am to 5.30pm, Saturday 9am to 2pm
By email: Click here for email support
If your product is out of warranty contact BT's recommended agent
By phone: 0800 980 8999
Message 3 of 5
Sounds possible reason, phone is 2 years old so out of warranty, thanks Keith
Message 4 of 5
Oddly enough, it does seem to be a problem with some BT Branded phones. The BT4600 is know to have this issue and has been reported on this forum. I have one BT4600 handset with exactly the same issue, so its either a fault with the earpiece itself, or the internal electronics.
You may be able to get a replacement handset from Discomm, who are the authorised spares supplier.
Message 5 of 5
Thanks Keith, I will try Discomm. Failing that I will buy a new phone (not this type again though), only ever keep a landline going so my non mobile using parents can call.
Many thanks
Lisa
