Message 1 of 11
Answering machine
Why has my answering machine stopped playing messages?  I have a BT6510 Nuisance Call Blocker cordless landline phone and it has worked fine for years so far.  Pamela
10 REPLIES 10
Message 2 of 11
Re: Answering machine
are you a BT broadband and phone customer?
Anonymous
Not applicable
Message 3 of 11
Do you really mean stopped playing or stopped recording? If the latter then maybe you have voicemail enabled on the line that's intercepting the call first.
Message 4 of 11
As far as I know it records messages. It tells me there is a message, then cuts out.
Message 5 of 11
Anonymous
Not applicable
Message 6 of 11
Then it sounds like it's faulty. Check the manual for how to perform a factory reset of the base unit but be aware it may lose your contacts.
Message 7 of 11
Thank you.  I will try this.
Message 8 of 11
I have tried this but it does not help.  I have also been trying to get help from the number that BT gives, but when I try their technical help I just get charged for a recording but no-one answers.  Do you think the base has failed?  Pamela
Anonymous
Not applicable
Message 9 of 11
Impossible to say for certain without trying a replacement, but difficult to imagine it's anything else. A quick look at that auction site shows the same model for sale around £15-20. So if you're otherwise happy with the phone, maybe pick up another to try. If that works you could always re-register your existing phone to the "new" base & just use it as a second handset.
Or look to upgrade to a later version from somewhere with a no quibble return policy like Amazon or Argos. If there's still an issue you can then just return.
Although cheapest of all would be to just turn it off & use the free BT Voicemail.
Message 10 of 11
Thank you for taking the time to give me such a helpful reply.  I was advised to turn off answer machine, then unplug & plug in again, & after doing this twice I was able to record and play a message, and play some old messages, but then it stopped again, so it seems to be an intermittent fault.  Anyway, I will investigate the BT service.  I didn't know they had a free one.
Pamela
