Message 1 of 3
BT Business SmartHub 2
Hi, I have a SmartHub2 for Business which I have just turned into a Modem by following the instructions to enable Bridge Mode.
I found out online a username: [email protected] to connect with my Synology Router via PPOE, I tried the auto-ip originally and this did not allow me to connect at all.
With the above login I was able to connect and get access to the internet. My issue now is that I am not getting assigned my static IP. Is there a specific login for each account which will provide the correct IP details for the account? If so how do I obtain those?
Regards
Matt
2 REPLIES 2
Message 2 of 3
Re: BT Business SmartHub 2
as a business user you need to post here as this is residential forum
https://business.forums.bt.com/
Message 3 of 3
Business accounts have their own individual logins, which you should have been supplied with when you started your contract.
