Message 1 of 11
BT Digital Phone stuck on Synchronising Handset Data X42-F81
2 of my handsets are stuck in a loop stating "Synchronising Handset Data", no amount of battery removal, pressing the red button or resetting the hub will stop them, I might as well throw them out.
10 REPLIES 10
Message 2 of 11
Re: BT Digital Phone stuck on Synchronising Handset Data X42-F81
Have you tried replacing the batteries with just ordinary alkaline just to test as long as not inserted on charger.  Even though existing batteries show charge they may be faulty and given incorrect reading. If phone work then just replace batteries with new rechargeable batteries
Message 3 of 11
Hi @herrbohnen   Battery removal is no good, they need new rechargeable batteries. Common problem.
Message 4 of 11
Bought and fitted new batteries, still the same
Message 5 of 11
In the bin they go then  🙄
Message 6 of 11
did you try resetting the SH2 now you have new batteries in the handsets?
Message 7 of 11
Yes and yes
Message 8 of 11
It's a pity they don't have a reset pin hole like other devices
Message 9 of 11
Message 10 of 11
Hi @Beckham37,
Welcome to the BT Community
Are you having the same issue with your handset stuck on synchronising? Have you tried a reset of the handset and a reset of the hub/router to see if that resolves the issue?
Alex
