Message 1 of 2
BT Enterprise SH31B - Fails to update, not checking server
Hi,
My BT Smart Hub 3 has been online for exactly:
System uptime:
1 Day, 22 Hrs 44 Mins
Yet, my Hub is still refusing to upgrade from firmware version:
Firmware version:
r1.34.0-R-994210-PROD-83002r 1 . 3 4 . 0 - R - 9 9 4 2 1 0 - P R O D - 8 3
I'm pretty stuck as I know that there are newer firmwares than this one, but whenever I contact BT Support the only reply I get is "this is automatic". That isn't good enough and I think I have a faulty Hub as this device has never checked for updates from BT.
This connection is an FTTX connection (FTTP with External).
Please can someone assist?
1 REPLY 1
Message 2 of 2
Re: BT Enterprise SH31B - Fails to update, not checking server
This is the BT residential forum, you need to post on the business forum.
