Message 1 of 8
Recycle Old BT Home Hub
We had a clear out in the loft and found an old BT Home Hub 5 that's been there for a couple of years (before the mandatory return process began).  I have been searching the BT website for instructions on how to send this back but I cannot find any instructions.  The only instructions I can find are for the current mandatory return process where you have a bag/box to send it back in.  These don't work for me as I don't have the bag/box and none of the helpdesk options appear to cater for my scenario.
I would rather return the Home Hub to BT for recycling than just throw in the bin.
7 REPLIES 7
Message 2 of 8
Re: Recycle Old BT Home Hub
You could just take it to your local recycling centre.
Message 3 of 8
you can phone CS 03301234150 and request a return bag
Message 4 of 8
Thanks.  Went for option 3 on the broadband option to speak to someone about orders as none of the options were an exact fit and the lady has arranged for a bag to be sent out to me
Message 5 of 8
Thanks for opting to return it to us to recycle @chopper32uk
Have a great evening.
DanielS
Message 6 of 8
I've tried the number but none of the options applied to a request for recycling bags. I now have 2 old home hubs and a digital phone to recycle. Hmm....
Message 7 of 8
Hi @Lynne4,
Welcome to the BT Community
There is not a specific menu option for returns bags, but when calling if you just select the options to speak to our broadband technical team, they will be able to get a returns bag request raised for you.
Alex
Message 8 of 8
Thank you for this
yes, I have now been called back so just need to wait for the bag. 😊
