Message 1 of 3
BT Home Hub 2. How can I delete the Technical Event Log "WITHOUT RESSETTING HUB"
I see from the forum that deleting the logs on a Home Hub 2 is not an issue.
But I do NOT want to loose all me settings doing a factory reset. .  The log is well over several hundred pages long and getting longer. I have around 16 devices and some set up with port forwarding, one in a dmz and entering all that again would be a nightmare, I have backups but that puts logs back - pointless.
Can Someone please edit the firmware so as we can delete logs with time choice ie 1 week, 1 month, 6 months, 1 year or delete all.
Thank you
ID
2 REPLIES 2
Message 2 of 3
Re: BT Home Hub 2. How can I delete the Technical Event Log "WITHOUT RESSETTING HUB"
Back up your configuration file, do a factory reset, and then restore the saved configuration file
Message 3 of 3
Why do you want to delete the log?
