Message 1 of 3
Complete WiFi
Is there any advantage in keeping an ethernet link between router and WiFi disc?
2 REPLIES 2
Message 2 of 3
Re: Complete WiFi
As long as you have good wifi connectivity, no.
Message 3 of 3
Re: Complete WiFi
The idea of the disc is to do away with cable connections, use the BT App to find the optimum place for the disc and make sure the light (on the disc) is orange at a minimum, ideally constant blue
