Message 1 of 19
BT Homespot Z3J and Kindle
  • I have  BT Homespot to extend the range of the wifi into my bedroom (stone walls). This works well. However since I bought a new  edition Amazon Kindle (11th ed) I have not been able to connect to BT Homespot. It can see the wi-fi but asks for a password. I have tried using the Virgin Media wifi password but it doesn't recognise this. I have been through all the setting on the kindle and can't see what I am missing. Very grateful for any solution that doesn't involve me getting out of bed to find a signal to synch to where I have read to on my phone! Thank you.
18 REPLIES 18
Message 2 of 19
Re: BT Homespot Z3J and Kindle
It will be the wifi password of the 'homespot' (whatever that is, or do you mean hotspot). The default password should be on a label somewhere on the device or with the documentation.
Message 3 of 19
Hi @opalGill welcome to the community and thanks for posting the Home Hotspot range of extenders all have a pull out card on the back of the hotspot with the wifi password details.
Neil
Message 4 of 19
  • Thank you Neil, I have looked and see no pull out card...I have had them some time.
Message 5 of 19
Thank you...HomeSpot is how it appears in wifi settings. Nothing in any of the devices I can see. Will have a look in original documents. My phone has only ever needed the normal WiFi password to connect.
Message 6 of 19
@opalGill the link in my post will bring you to the product support help pages for the home hotspots. If your Kindle has a WPS facility you may be able to connect that way.
Neil
Message 7 of 19
@opalGill
I think you will find the information printed on a label on the device itself. The pull out card is just for convenience.
It should give you the admin access code, and the default wireless password.
Anonymous
Not applicable
Message 8 of 19
The card should be here:
But as @Keith_Beddoe said, if you unplug the device the info should be repeated on a label on the plug side.
Message 9 of 19
No card there on mine.
Message 10 of 19
Look on the back of the plug.
