Message 1 of 3
BT Premium phone trio handset
Recently purchased the trio handset, handset 1 on the base station works perfectly however handsets 2 & 3 have a problem, if I make an outgoing call I can hear them but they cannot hear me, if I receive a call they can hear me but I cannot hear them  and the same happens if I use my mobile to call the handsets.  I have registered the handsets and re-set the phones as advised by BT however the fault remains, in conversation with BT Help they quoted a fault code of 1600176 which means nothing to me. Has anybody had a similar problem or found a resolution to this, I have searched the manual but that did not provide an answer.
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: BT Premium phone trio handset
Weird! What happens if make internal calls between all three handsets?
Message 3 of 3
Hi,
Thanks for the response however because the seller on Amazon failed to remediate that problem I arranged for Amazon to collect the products today and I re-installed  our old BT slimline handsets, the base station still works OK but have not tried the second handset. I will seek to get alternatives.
Thanks G
