Message 1 of 4
BT Smart Hub 2 FTTP version locked to BT?
Hi all.  I’ve got a couple of quick questions about the BT Smart Hub 2 FTTP (fibre to the property) version.
Firstly, is it locked to BT only?  I’ve heard a rumour that it will also work with Plusnet, but not other providers?  Is this true?
Secondly, I’ve got the FTTP version of the hub.  I assume this would also work with FTTC (fibre to the cabinet), and also bog-standard broadband via copper telephone cables if the situation arose?
Thanks in advance for any help anyone can provide.
3 REPLIES 3
Message 2 of 4
Re: BT Smart Hub 2 FTTP version locked to BT?
YES
YES
Message 3 of 4
Great, many thanks for the swift response, much appreciated.
Anonymous
Not applicable
Message 4 of 4
If you're planning on moving to Plusnet they supply their own version of the SH2, so you may as well take that.
