Message 1 of 3
BT Smart Hub 2 squeaking / bleeping and not working
Hi everyone,
My BT Smart Hub 2 has just stopped working completely and is making a regular low volume, high pitched  squeezing / bleeping noise. The hub doesn't light up anymore and holding reset for a whole minute doesn't change anything.
When I unplug it, the bleeping stops. I have tried it in multiple plug sockets all with the same effect.
It looks like it has died. Any help?
2 REPLIES 2
Message 2 of 3
Re: BT Smart Hub 2 squeaking / bleeping and not working
@Domm2k
Probably the power unit, as those types of switched mode units often fail.
If you are still in a contract, ask BT to send a replacement.
Message 3 of 3
Then phone CS 150 or 0800800150 from mobile and ask for replacement
