Message 1 of 2
BT Whole Home - How to assign static IP address for specific device?
I have a BT Whole Home wifi setup with 3 discs, and I am looking to assign a static IP address for a security camera I am setting up with RTSP.
I can't find the setting to enable that in the mybtdevice web panel.
I can see how to assign a static IP for the Disc itself, but I am needing to apply it to a single device.
Thanks,
Liam
1 REPLY 1
Message 2 of 2
Re: BT Whole Home - How to assign static IP address for specific device?
A 'static' IP address can only be set on the device itself.
If you mean address reservation, whereby the hub always issues the same address, then go to Advanced Settings > My Network > My Devices and select the device you wish to reserve the address on and select Always use this IP address.
