Good afternoon,
As title, how do I display a list of the numbers I've blocked, please?
Sorry if this is obvious, but I'm very ancient!
Thank you.
Solved! Go to Solution.
Unfortunately, you can't.
You either have to temporarily turn off call blocking or add the number to the Allowed list (that you also can't view!).
On my BT4600 which is similar, you can look at the incoming call log and it shows "blocked" against any blocked entry. You can then edit the entry and unblock it by adding it to your phone directory.
