Message 1 of 6
Bt big button 200 v2 batteries question
Hello everyone!
I just bought this phone second hand and i'm wondering what the batteries are needed for exactly?
The phone seems to ring and receive and make calls alright without the batteries and the calling light still flashes. The manual makes no mention of what the batteries could be for! So i'm confused about this.
Thanks!
5 REPLIES 5
Message 2 of 6
Re: Bt big button 200 v2 batteries question
@RetroRemix
I think you will find is for the 1571 light and hands free speaker.
Anonymous
Not applicable
Message 3 of 6
Most likely to backup any stored "quick dial" numbers if the phone is unplugged.
Message 4 of 6
Ah ok!
Do you know how long the batteries usually last before they need to be replaced? Is it a long time?
Thanks!
Anonymous
Not applicable
Message 5 of 6
If it is only backup for volatile memory then if you buy decent alkalines, probably years!
Should be easy enough to verify which features work without batteries.
Message 6 of 6
Ok that's good to know they last for years potentially!
I already did try everything I could with this phone, with and without the batteries, to see what changed.
So when I could see nothing different either way, it's why I asked on here to be sure if they were really needed or not. 🙂
