Message 1 of 5
Hub manager icon
I used to have an icon for hub manager on my desktop. Please can anyone tell me how I can get one for my new computer?
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Hub manager icon
Open the hub manager by typing 192.168.1.254 into the address bar of browser. When the page opens there will be a padlock icon to the left of the address. If the browser window is full screen resize it smaller. Then just click & hold the padlock icon & drag it to a space on the desktop. You can then click the name & change it if desired.
Message 3 of 5
Thank you, rbz5416.
Thank you for your swift response to my question. It solved my problem immediately. (I did have to unlock it first)
Kind regards
PAT-MAN
Anonymous
Not applicable
Message 4 of 5
Although as it's just an IP address in a browser, the usual way would be to just add a bookmark in the browser as you would for any other web site.
Message 5 of 5
Thanks once again. I will bear that in mind for future use.
