Message 1 of 4
Bt disk
Do you put your disk where it says excellent/ good connection or where the connection is poor
3 REPLIES 3
Message 2 of 4
Re: Bt disk
excellent/good  - you are trying to get a connection between hub and disc
Message 3 of 4
Re: Bt disk
It’s only really 1 room in the house that doesn’t get a good connection that’s why we got it so wasn’t sure
Message 4 of 4
Re: Bt disk
