Message 1 of 2
Can I set my BT Hub to automatically restart daily
I have an ongoing problem with the WiFi on my BT Hub.  3 or 4 times a week WiFi stops working.  Omitting a LOT of detail, this should be fixed in a couple of months. In the interim, rebooting the hub works.
So I would like to automatically set the Hub to reboot at, say, 3am each day.
Is there a way to do this?
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: Can I set my BT Hub to automatically restart daily
Not from within the Hub but a simple plug-in mechanical timer would do the job.
