Message 1 of 5
Deleting event log in BT smart hub
Hi,
Could someone help to describe how to delete event log in a BT smart hub 2 as there is no option in the menu. I tried factory reset but it does not work. thank you
4 REPLIES 4
Message 2 of 5
Re: Deleting event log in BT smart hub
A full factory reset using the recessed button will clear the log, but why do you want to clear it anyway?
Message 3 of 5
I am returning itm and like to delete the log
Message 4 of 5
Hi @Parham and welcome to our community.
Thanks for posting about the hub. @licquorice is correct. Just press the recessed button to reset the hub. Do you need a returns bag to send it back?
Cheers
David
Message 5 of 5
Will try, Thank you very much David.
Already ordered the return bag
