Message 1 of 8
Extending a smart hub 2 with a black disc
I want to extend my wifi (Smart Hub 2) and am considering picking up a cheap black wifi extender disc. Will I have any issues getting it to work, assuming it is fault-free?
I contacted BT about getting an extender disc, but they would only provide one by increasing my monthly fee, and that works out at over £100 per year.
7 REPLIES 7
Message 2 of 8
Re: Extending a smart hub 2 with a black disc
If you can find a genuine BT black "Complete WiFi" disc to buy, then yes, it'll work if fault free (of course). A  quick Google search shows a few for sale, not sure how the vendors get them since they are normally just sent by BT to its customers if they have an appropriate contract.
Message 3 of 8
Just to be clear, I have  BT Business Hub. Will that still work OK?
Message 4 of 8
No idea, ask on the business forum
Message 5 of 8
eBay is seemingly awash with WiFi discs. Just like all the BT and EE routers that somehow never make it back to the returns centre.
Message 6 of 8
Will do, thanks!
Message 7 of 8
Just for completeness, I wanted to let you know that I bought a second hand extender and it works fine with my Smart Hub 2 on a business account.
Message 8 of 8
Thanks for the update, good to know it works.
